RCU Forums - View Single Post - Mechanical Retracts ,Pushrod Info
Old 01-31-2003 | 03:44 PM
Richard L.'s Avatar
Richard L.
My Feedback: (24)
Default Mechanical Retracts ,Pushrod Info
Just took some pictures of the retract servo in my Mitsubishi Zero. Here is a picture of the servo with the wheels in the full up position:
Here is a picture of the servo with the wheels in the full down position:
Note how the pushrods are bent so that they don't touch each other and the EZ connectors.
You also need to bend the pushrods so that they go over the wheel wells. I will try to get a picture of that later.
Also, you must measure the stroke of your retract mechanism. Another word, pull the cam all the way out and mark a spot. Then push the cam all the way in and mark another spot. Measure the distance between the two marks. This is the distance the two pushrod connectors on the servo arm must be separated by since the retract servo swings 180° from one end to the other end. If the connectors are spaced apart by more than this distance, then you will be putting extra stress on the servo. If the connectors are spaced apart by less than this distance, then your wheels might not fully lock in the down position. If you are using Hobbico mechanical retracts, then the distance between the two pushrod connectors on the servo arm is around 1-1/16", probably closer to 1-3/32".
