RCU Forums - View Single Post - Engine won't idle
Old 12-26-2006 | 12:20 PM
Big_Bird's Avatar
Big_Bird
Default RE: Engine won't idle
Sure sounds like a throttle servo problem because when the throttle plate closes quickly, the engine should go to idle quickly. If the ends of the throttle plate are worn or the carb body is worn, this may be causing an idle problem.
