RCU Forums - View Single Post - Mounting 2 stroke engine inverted question
Old 12-26-2006 | 05:59 PM
rlipsett
Default RE: Mounting 2 stroke engine inverted question
the big problems with mounting an engine inverted can be solved by puting in a hotter glow plug with an idler bar to keep the fuel from quenching the coils and starting and tuning the plane inverted so that the engine is upright the first time so you can adjust everything too optimal so there will not be excessive fuel pouring into the glow plug. It usually runs good after that.
