RE: Brillelli 25GT on a CMP Giles-202
Just wanted to add a post regarding this plane. I must say that this ARF was one of the easiest to put together that I have ever built. The fit and finish was perfect not one miss alined hole or ill fitting area. I did change out the pin hinges for robarts but other than that this is one nice kit. I powered mine with a MOKI 1.80 on 5% nitro with a 20 oz tank.. WOW.. It is a complete missile . The plane needed 2 beeps of down for perfect level flight. It slows down nice for landing . Over all weight came in at 12 lbs 5 oz. I'm not sure that you can get much lower maybe 5 or 6 oz if you left out the on board glow driver... Vertical is unlimited and you can even hold it in a hover for a bit. But the control areas are kind of small so it becomes a bit tricky. The aircraft flys like a pattern ship. Very crisp rolls, level inverted flight. Knife edge with very little to no coupling... Did I mention how fast this thing is... A++++
