RCU Forums - View Single Post - TC3 and TC4
Thread: TC3 and TC4
Old 12-26-2006 | 10:25 PM
Taffey's Avatar
Taffey
Default RE: TC3 and TC4
ORIGINAL: alangsam
need some help from an experience TC3er! I have been racing 1/10 and `1/8 scale trucks for some time and am new to on road. i picked up 2 TC3's and one of the things i am puzzled by is how to set the gear mesh properly. I have the cam attached to the motor then i push it down in the slot and then put the combo heatsink motor hold on and screw it down. Do you adjust the mesh by rotating the cam slightly to where you want it then put the heatsink on - i was thinking that when you tighten this down it moves the cam??
Andy
Hi Andy-
You are correct: gear mesh on the TC3 is set by rotating the motor (and attached cam) slightly. As long as you make sure that you are pressing down firmly on the motor, it will not move when tightening the heat sink screws. Tighten down the screw without the spring first and the one with the spring second. The spring should be about halfway compressed when you are done.
I hope this helps!
