RE: trouble starting himoto eldorada
did it run good before the spur gear was stripped? did you take the engine out when you changed the spur? do you have the hoses the right way? (dont take as an insult) does the tank hold pressure, blow in one hose while pinching the other one. will it push fuel out if you pull the hose off the muffler and blow into it?
