er no i dont think so.. but i cant be totally sure
however
if you intend to get into RC bit by bit then you can buy a propper radio from the get go
" A stand alone"
Most usually come with servos aswell i think.. but you may need to get your frequency crystal seperate!
lest see what towerhobbies have got there
http://www2.towerhobbies.com/listings/cat-j.html
id get a 6 channel one for starters but i have no idea how deep your gonna go so you decide if you want more channels..
ill proly stick to foamy's......... maybe haha.. you never know..
thinking really hard about getting the US Aircore colt 40 and stepping up the power with a .61 engine
cuz i read its a heavy plane and needs power.. ill need to ask round on here to see if that feasable
here are the links in case your interested
engine
http://www2.towerhobbies.com/cgi-bin...&I=LXUR77&P=ML
colt 40
http://www2.towerhobbies.com/cgi-bin...&I=LXKH28&P=ML
it can be built as a tail dragger which is what id do if i got it.
Here you see the updated Tx of the one which i have
http://www2.towerhobbies.com/cgi-bin...I=LXKAJ1**&P=0
i have the discontinued Futaba 6exa which i got from someone here on Rc universe actually..
no servos but they were kind enough to let me have the crystal (thank you so much!)
in the end i only payed 80USD for it and to me that was a great deal (but im a noob what do i know right?)
if cost is a serious factor id recomend getting a second hand one on here from someone in the classifides..
but keep in mind that if your gonna go with a bigger gas model later on it might be cost effective to get a new on with servos and all.
For me, i just got the Tx seperate then im gonna get a buddy cord and some kinda usb adapter for the flight sims
found here
http://www.mftech.de/usb-interface_en.htm
here aero fly offers an
AeroFly Pro Deluxe CD with USB interface cable or many different types of transmitters
http://aerofly.com/www/how_to_buy.html
here you can check out the requirements
http://aerofly.com/www/requirements.html
Supported transmitters
The following radios are compatible with the AeroFly Professional Deluxe USB interface. Unless otherwise noted all of the ollowing radios except some JR and Futaba radios work with the included adapters:
Graupner (FM-314, FM-414, MC10, MC12, MC14, MC15, MC16/20, MC18, MC19, MC22, MC24)
Futaba (F14, FC16, FC18, FC28)
Multiplex (Royal Evo-7/9/12, Profi MC 3000/4000, Cockpit MM, 2020, 3030, 4040)
Lexors Nova 4 and Nova 6
HITEC
Sanwa
Robbe
The following radios require a separate adapter:
JR radios X-347, X-387, X-388, X-756, X-3810, 652, 8103, 6102/2610, 9X/9303, 10X and Graupner MX12, MX16 and MX22: These radios require a special 3.5mm mono adapter. This adapter is available direct from IKARUS (order number 31036) and its dealer network and from the dealer network of J. Perkins Distribution in Great Britain.
Futaba radios 4YF, 6EX, 7C/FF7, 9C/FF9, 14MZ: The required square adapter is available direct from IKARUS (order number 31036) and its dealer network or from the dealer network of J. Perkins Distribution in Great Britain.
Futaba FX-15 and FX-18: These radios require a 2.5mm mono adapter available direct from Robbe (Robbe order number 1-8383 (FX))
i hope all this helps
xero.
