RE: BVM Kingcat Throws
The KC needs a bunch of throws. I sold mine so this is from memory. The ailerons will need about 1.25". Elev 1.75, rudders 1". Flaps take off 15 dgress and landing 35 degrees plus 1/2" of crow on the ailerons. Set the CG per plans and modify it later. Set triple rates for everything to find out what you like. Good luck....
