RCU Forums - View Single Post - Ryobi and Homelite engine dimensions
Old 12-27-2006 | 10:21 AM
captinjohn
Default RE: Ryobi and Homelite engine dimensions
The Quadra like Dave says is also a good engine. It kinda depends too on the other planes you may get in the future to use same engine. If you do not plan on light-weight aircraft in the future....the Quadra is a good choice...if it runs good and is not crash damaged (bent crank). Good luck, Capt,n
