RE: Is this the right CA for hinges?
Hi!
You don't wick the hinges...Just insert them and see to that the gap between the flying surface and wing/stab/fin is next to zero...then put on a few drops of thin CA (like Flash and Zap)....only when the glue has dried ...after some minutes to be sure all has dried...then you wick the flying surfaces(elevator, Aileron, rudder) to their full deflection.
Regards!
Jan K
Sweden
