you mean the spider gears? you should not have to replace them. just the final gear (big one) and the gear which sits inside the final gear. make sure you shim them correctly. did they come with shims?
ORIGINAL: tamagooch
hi guys
wanna know what exacly u get when u buy a heavy duty final gear set cause mine only came wif 2 gears and i hav no clue as to how i am going to install the smaller gear thanx
