RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 12-27-2006 | 06:45 PM
  #4580
Jellyson's Avatar
Jellyson
Default RE: E-FLIGHT BLADE CP
you _might_ be able to get it to work, There is an issue involving the arming of the throttle esc in the 4-in-1, it depends on unknown factors. So if your eccpm mix isn't set just right the servos will move but the escs won't arm.
If you can get past this problem then you might be able to use it like you want.
