RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 12-27-2006 | 10:04 PM
  #487
choppersrule
Default RE: E-FLITE BLADE CP PRO
Jellyson,
Been on and off the net for a few days, had computer troubles. Ended up, reformatting the hard drive and reinstalling the whole nine yards. And yes, I keep back up of everything. Got 2 hard drives and back up almost everynight, only takes five minutes at most. Then make a copy of that about every 2 weeks on a DVD disk.
In your post #481, you've said a ton of very useful information. Man this is a tuff question, what 's the best mod. I think before any mods, you just have to do the basics in setup. Swashplate level and right on, and of course pitch and tracking. I have several helis, my CP is the experimential one. I've got it tweaked so fine, over a period of time, it hovers with almost zero input. Input to control sticks should be very gentle and small. 1/8 inch to 1/4 inch is more than sufficent. Of course, if you're heading into a wall, then jam it. Also, depends on the type of flying you want to do. Backyard, mild aerobatics, 3D stuff. Always, to many decisions.
Back yard, go with the swash plate and the align links. Aerobatics and 3D, swashplate, links, gyro and dd, ops, also, upgrade to the HS55 Servos. Need to modify the HS55 servos if you have the stock Cp/CpPro transmitter. I have that info if you need it.
Jellyson, hang tight, catch ya tomorrow,
Dave / Choppersrue
ORIGINAL: Jellyson
What do you think, robmoney? choppersrule/dave? barracudahockey? H_H? anyone?
what's the single most handling improving mod for the BCPP?
I'd have to say the aluminum swash with the align links.
The single best performance mod, after the gyro, is the DD tailfeathers for sure.
Any other opinions to get noguy's bird tightend up?
