RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 12-27-2006 | 10:11 PM
  #89
PilotTiger
Default RE: New CDI - opensource project JMJ and Bigboat
ORIGINAL: Bigboat
BTW, you have to fit the hallsensor about 40 degrees beforo TDC.
Into the Exelsheet you can manipulate the curve as you like.
I will do that. That's the easiest part. :-)
Isn't coroplast to fragile to build a 30cc (?) plane ?
They use it also for 3d and indoor planes ?
If you use the 4mm stuff it is not. For indoor and 3D they use mostly 2mm.
