RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 12-28-2006 | 02:53 AM
  #494
moejoe
Default RE: E-FLITE BLADE CP PRO
hey noguy, i am also brand new to this thing called BCPP lol, i was messin around indoors for the first few days and i was getting kinda nervous that i'd never be able to hover, then i realized something, when your inside the aircurrents from the disk will bounce off of EVERYTHING, making it always feel like your flying in ground effect, and if your heater turns on, well that's just one more air current your fighting, anyways, if it's completly calm *wind* outside then definitly practice out doors, or if you know anyway to get yourself into a gym to fly that is the most fun i've had so far, in the gym with nobody else, not only was it a thousand times easyer to hover but there was room enough to start moveing the thing forward *and backwards and sideways lol* o and b/c i am a newb tho i do have a question for anyone on here who would like to help, my servo's the two that are mounted next to each other, that control left and right, one of them is slightly above level, but that linkage is also slightly shorter then the other makeing the swashplate level, will this effect anything, i remember on the airplanes that i flew you chould actualy manualy set some "expo" by changeing the angle of the control arm, or am i not remembering correctly, anyways, should i try and re level that swashplate with a level control arm or not?
