RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 12-28-2006 | 11:54 AM
  #3933
Jason321
Default RE: Air Hogs Aero Ace!
I just purchased my AHAA jet yesterday and after reading some tune up tips I decided to move the battery fowrad to reduce the porpoising. However now the thing won't run. It only turns on if the charger is hooked up to the plane and the jet is in the on position and the charger is in the power position.. Even then the rudders cut on and off depending on the throttle position. If I turn the plane off and the tx is in the charge position , the green charge light does NOT turn on. I've looked to see if i spliced a wire but everything seems good. Any advice would be great. Thanks.
