RCU Forums - View Single Post - Official HPI MT2 Thread
Old 12-28-2006 | 05:08 PM
  #11066
Nitr0-is-Deadly's Avatar
Nitr0-is-Deadly
Default RE: Official HPI MT2 Thread
ORIGINAL: djheptic
maybe you have lost 4wd. if the rear of your mt2 fishtails maybe your front diff has gone. i had mine running on the grass today it was wet and i run the dirt bonz. they were fine. ill post the video later.
ORIGINAL: nitro-is-deadly
does any 1 have a problem with gripping grass with their mt2???
like i went to the park and theres a huge field!
im going about half throttle and the trucks kinda slipping side to side
then i punch it and the back end fishtails
keep in mind this is the sticky compound dirt bonz!! and they cant grip grass at full throttle!!! all they do is cut the grass(throws all the grass in the air like a mower)
any 1 else have dis problem..i think its a good problem tho a sign of power
well when i lift it off the ground all 4 wheels spin but mind you there is no pressure.
so to test the diffs just hold for example the right fronmt wheel and spin the back right wheel?
if it slipps easy its bad diffs if it doesnt then wat the hell
