RCU Forums - View Single Post - OS FX vs FXi ---Is there really much difference?
Old 12-28-2006 | 05:25 PM
pbjones81
Default RE: OS FX vs FXi ---Is there really much difference?
ORIGINAL: w8ye
The FXi is the RTF trainer version of the FX. It has a low compression head. Therefore is easy to start and adjust but doesn't have as much power as the original FX. The FXi also has needle valve setting restrictors.
The FXi has a lot more power than the LA series engine.
The FXi is easy to spot among FX engines as the head fins are rounded front and rear like on a LA engine. It also has the needle valve restrictors.
Thanks for the replies guys....Do you know if there is any noticeable difference in noise? It seems to me that since the FXi is lower compression, it would be slightly quieter....is that correct?
