Field rules?
This is the club located near my house and I was reading through the rules. These rules seem to be a bit restrictive and strict. Is this the norm for r/c clubs or is this over restrictive? Thanks
MIDWEST RADIO CONTROL SOCIETY FIELD RULES
April 1999 (You are expected to save and follow these rules)
1. SAFETY FIRST
2. All pilots and pilots in training are expected to be familiar with and abide by these field rules and the current AMA safety code. All members are to consider themselves safety officers.
3. All pilots, pilots in training and guests are required to have a valid AMA license.
4. All aircraft will be started and run in a direction so that the prop wash and exhaust is directed towards the runway. All aircraft must use a restraint (restraints are located under the shelter table and restraint holes are placed at regular spacing). NO RESTARTS ON THE FIELD.
5. Prop spinners or acorn nuts which meet AMA standards must be installed on all airplanes flown at this field.
6. All model aircraft must not exceed 98dB at 9 feet.
7. When more than one aircraft is flying, the runway must be kept clear. Observers are recommended to advise the pilot about people on the field, other model aircraft and low flying full scale aircraft. When retrieving aircraft on the field, pilot will call "ON THE FIELD" to alert all other pilots of the situation. When clear of the field pilots will call "CLEAR".
8. Take offs MUST begin on the far side of the runway centerline. (including hand launches) If on take off roll the aircraft changes direction toward the pilot line/pit area, the take off MUST be aborted IMMEDIATELY.
9. Landing aircraft have precedence over take-offs. Dead stick landings have precedence over all model flight activities. It is the responsibility of all those experiencing a dead stick to call out "DEAD STICK" to alert others of the difficulty. All pilots are responsible for maintaining safe clearance until the dead stick aircraft has been landed and recovered from the field.
10. In the event of any emergency which demands an immediate landing of any aircraft, all personnel must be made aware of the emergency. All pilots will "pass the word" down the flight line for all to hear and will then maintain safe clearance from the affected aircraft.
11. Guests are permitted up to a maximum of three visits per guest per year. All members are responsible for their guest's activities and the understanding of these field rules. 12. All new members will require flight certification, including field rules, from a club officer or instructor, prior to issuance of their membership certificate. Beginning pilots (students) will be certified through the club instruction program. Student flying is permitted only on instruction night (Thursday) or by appointment with a club instructor. Students only on student night after 6:00 PM.
13. No landings, take offs or taxiing are permitted in the pit area. ALL AEROBATICS (INCLUDING LOW FLY-BYS) are to be executed over the north side of the field beyond the cut part of the runway. NO FLYING IS PERMITTED ON THE SOUTH SIDE OF THE SAFETY NET. (also known as the WOOLEY line).
14. Helicopter flying area is located east of the main runway and south of the WOOLEY line. Helicopters are permitted to fly south of the WOOLEY line but NO FURTHER SOUTH THAN THE CUT PART OF THE HELIPAD.
15. All glider and hi-start equipment or winches shall be set up on the up wind end of the pit area, so as not to enter the pit area when stretched out (launching). To avoid entering the runway area glider pilots may fly from the west end of the runway south of the WOOLEY line. NO FLYING IS PERMITTED WITHIN 100 FEET OF FIVE MILE ROAD.
16. Pilots must stand at the piloting position indicated by the painted patio blocks located behind the safety net. This reduces the possibility of radio interference and also provides a safety zone between the flight line and the pilots.
17. All 50 FCC authorized frequency channels may be used at Midwest R/C as well as legally assigned HAM channels and the 27 MHz aircraft channels. Remove the frequency pin and insert membership card BEFORE turning on transmitter. Five channels have been assigned priority for helicopters (11,12, 21, 27 & 29). If a heli pilot has that frequency, then he has priority as long as he is there. Like wise all other channels are airplane priority. In the event that more than one person at the field is on the same frequency the frequency pin must be passed to the next person after the completion of one flight until everyone has had an opportunity to fly (within the heli/airplane grouping). When finished flying return the pin to the frequency board.
18. If in the opinion of a member, a flier continually has shown the inability to control his aircraft (or if otherwise is demonstrating unsafe flying habits), the incident shall be reported using the safety incident report form (located in the ammo box above the small shelter) or to the safety or club officers, for appropriate action (discipline, additional training etc.).
19. NO FLYING IS PERMITTED WHILE THE FARMER OR MOWING CREW IS MOWING ANYWHERE ON OR AROUND THE FIELD.
20. There are no trash receptacles at the field, so take what you bring.
21. The first aid kit is located above the small shelter. Notify the club officers if items need to be replenished.
22. Spectators are welcome, but must remain south of the frequency board and signs so designating for their safety.
23. Engine break in or testing (run-up for extended periods) must be done near the picnic table on the east side of the driveway.
24. Flying hours are from 8:00 AM to Midnight seven days a week at the 5 Mile Field.
25. Not more than five (5) fixed wing aircraft shall be flown at one time.
Please NOTE orientation and position of things at the field. Note that take offs and landings are to be to the north of the field center line.
AIRCRAFT CHECK LIST: HELICOPTER (PRE-FLIGHT)
TRANSMITTER/RECEIVER BATTERY CONDITION: (ESV>4.9v RCVR; >9.6V TRANS)
FUEL/FUEL LINES REATTACHED
FREQUENCY PIN/CARD IN FREQUENCY BOARD
TRANSMITTER ON ANTENNA DOWN - CORRECT MODEL SELECTION
RECEIVER ON/RANGE CHECK RADIO SYSTEM
WAIT FOR GYRO INITIALIZATION
CONTROL SURFACES ORIENTATION/FUNCTION
TRIM LEVER POSITION OK?
FLIGHT MODE NORMAL/THROTTLE DOWN/THROTTLE HOLD OFF
GLOW DRIVER/IGNITION ON
HOLD ROTOR HEAD WHEN STARTING ENGINE
GLOW DRIVER OFF
BEFORE TAKE-OFF EXTEND ANTENNA
POST FLIGHT
RECEIVER OFF/TRANSMITTER OFF/ANTENNA DOWN
RETURN FREQUENCY PIN/GET MEMBERSHIP CARD
AIRCRAFT CHECK LIST
AIRPLANE (PRE-FLIGHT)
TRANSMITTER/RECEIVER BATTERY CONDITION (ESV>4.9v RCVR; >9.6V TRANS)
AILERON/FLAP SERVO CONNECTION
WING HOLD DOWN BOLTS TIGHT/RUBBER BANDS CORRECT TENSION
AIRCRAFT IN RESTRAINT (FULL FORWARD)
CONTROL SURFACES ORIENTATION/FUNCTION TRIM LEVER POSITION OK?
MAKE SURE PLANE OF PROP IS CLEAR – PROP TIGHT/SPINNER SEATED
ENGINE OPERATION/TUNING (GLOW DRIVER OFF)
POST FLIGHT
This page hosted by Get your own Free Home Page
undefined
undefined
More...
undefined
[Close]
undefined
[Close]
undefined
