RE: Pull Pull controls??
The first thing with Pull-Pull geometry is to make sure you have as close to a perfect rectangle arrangement with the servo end being one end of the rectangle and the control horn end as the other. Space the end of the lines equal distant out from the pivot point at each end. If you want to cross the lines that's OK.
