RCU Forums - View Single Post - Tightening props on cheap plasic spinners
Old 12-29-2006 | 06:32 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Tightening props on cheap plasic spinners
When you say "jam nut" do you mean the second nut like on a Saito or the one and only nut like a 2C? If it is the one and only nut you don't have enough. I had a St 51 that was the same way. The crank was just to short. Some props are thinner than others you might look at that. Or just use a spinner nut. I have great luck with those.
David
