RE: WACO YMF
Bill;
I really like the exaust pipes,look very scale. Your cowl looks larger than mine. If you don't mind,would you measure the distance across the cowl at the center line. I am liking the twin more and more. Are you using an on board glow system? Do you think my OS 120 would work if I come in around 12 lbs. I am using it on a Hanger 9 FuntanaX that weighs 13.5 lbs and it will take the plane vertical on take off,but it will not hang on the prop,but it has plenty of power.
Gaines
