Here are some pictures I took while waiting for the fog to lift. I ran out of time before the fog lifted so I didn't get to fly it yet [
In one of the pictures you can see where I put the battery in the tail from the bottom. 3mm depron foam painted black to cover where I cut out the monokote to install my Rx as far aft as possible, plus I wanted it black in thier anyways.
ORIGINAL: FNG
All up wieght (dry) is 93.1 oz. Thats is with a JR 7 ch Rx (mounted as far aft as possible in bay), 720mil 4 cell MIMH batt (just forward of the tail servos for balance), OS FS70 II surpass with the 90 deg inside muffler adapter, and a APC 14x4W prop. HS 81mg on the throttle, mounted in the most aft bay under the hatch. CG is just about as the manual states (4.75" aft of LE), perhaps just a touch aft.
Mark
