ORIGINAL: goldsticker
Will a Norvel AME 049/061 R/C carb fit on a Norvel AME 049 Control Line engine??
I am assuming that the 049 and 061 carb assemblies are identical... Do they infact use the same assembly part number?
It looks like the part number I should look for is 110159-RC
Venturi assemblies and carbs will fully interchange between the .049 and .061 engines -- what you have to pay attention to is the older vs. newer style crankcase. The earlier AAN crankcases used a glued in round body carb; the newer AAO or REVLITE engines have a thru bolt mount with square body carb or venturi.
If your engine has the bolted in venturi, then your part number should work.
