RCU Forums - View Single Post - 'Stock' Stampede Finally Finished
Old 12-30-2006 | 12:16 PM
cr85nut's Avatar
cr85nut
Default RE: 'Stock' Stampede Finally Finished
Sleepy what length rods do you use for the camber links and turnbuckles.
I have 96mm rod for tunrbuckle and 72mm rod for camber link will those work with the jato arm conversion?
Also what arm do you use for the front? the rear or front?
-Matt
