You only need to adjust the low speed needle if it nearly stalls out when you womp on the throttle from an idle. If it idles ok, leave the low speed needle and idle speed alone. Spitting oil at idle isn't really a problem. 2 strokes aren't meant to idle for long periods of time and load up with excess unburned fuel and oil at idle. So as long as it runs ok, just leave it alone.
ORIGINAL: TrailBlazer250
my car spits oil out of the exhaust when its idling. it smokes a little, but not excessively. my low speed adjustment is 2 1/2 turns out. Any ideas?
