Electric motor for an olympic II
If I remember right, they came with a cheap 05 motor. You can do better by going with a Magneic Mayhem with a gear box and a 11X6-7 "E" prop. THe motor is $20.00 from Tower. If you use the DG600 gear box that they sell for $14.00 you will need to retime the motor to run backwards, or you can get the gear boax from Hobby Lobyy that goes on the front like a cap. On a 6 cell pack it should take it up to be a small dot. An 8cell pack will get you there faster.
Dru.
