RE: What connections (tabs)
do you have the correct solder, normal solder wont work on the aluminium tabs. (i think you need zinc solder)
and be fast as the temperarure of the soldering iron is higher than the thermal runaway of the pack, so soldering slowly will result in a minature inferno!
