ORIGINAL: skycarven
flying-llama,
So if I get a standard NiMH peak detecting charger, that will work better? I might pick one up if that is the case if that is the case.
Actually, rereading the Axe CP manual (I don't have an Axe CP yet, my hovering ability needs to improve first),
the stock charger looks like a NiMH peak detecting charger (tells you when it is done, takes ~1hour for a full charge)
that can just handle the Axe CP battery.
If you do get another charger, make sure that it can handle the current and voltage rating of the Axe CP battery.
