RCU Forums - View Single Post - Noob Question
Old 12-30-2006 | 07:56 PM
Missileman's Avatar
Missileman
Default RE: Noob Question
This is for the ones I own.
The square part above your gearbox is designed to slide onto a beam that protrudes from the front of your plane. I have seen both wood and aluminum beams used. It can be glued on or a hole drilled and a wood or sheet metal screw put in.
