RCU Forums - View Single Post - Conversion for degrees of throw to inches
Old 12-31-2006 | 04:40 AM
Idigbo's Avatar
Idigbo
Default RE: Conversion for degrees of throw to inches
The easiest way is to simply draw out on a piece of paper. Measure the width of the surface at a point you want, then draw it, the surface its hinged to and the surface deflection you require, then measure the the distance at the trailing edge and Voila!!!
Much more tame on the brain cells, unless of course you want to do it the hard way!!
Ian.
