you must add
Well I'm not a pro but, I do want to say add right thrust. I believe without right thrust on your engine your rudder will be working overtime. You'll probably have to run with at least 3/16 - 1/4 inch of right rudder trim. This is OK for flying around, killer on landings and even worse in a cross wind.
protect your camera equipment, put in right thrust!!!!
You must be excellent on the sticks. How do you hold straight during hammerheads , must be a challenge keeping the wings straight before the nose drops, entering a spin. These are just a couple of problems I have encountered without right thrust. Maybe I should go to a smaller prop?????
