RCU Forums - View Single Post - official smartech buggy thread
Old 12-31-2006 | 08:35 AM
  #1926
docphysics's Avatar
docphysics
Default RE: official smartech buggy thread
well, if your idle screw is worthless than loosen the grub screw in the collet on the throttle linkage to pull the linkage towards the rear of the car a little bit so that at idle it closes of the barrel opening to less than 1 mm. Then when it is idling, use the throttle trim on the controller to fine tune the idle to where it will idle, but not stall and not roll.
