RCU Forums - View Single Post - Right Thrust
Thread: Right Thrust
Old 02-14-2002 | 04:47 PM
Rodney
Default Right Thrust
Put in the right thrust or you will have to retrim rudder for every change in throttle setting, the same goes for downthrust. Depending on the type motor mount you use, you should be able to change thrust setting after the initial flight by adding the appropriate washers to obtain optimum results. Rod
