ORIGINAL: Flypaper 2
Let's do some honest calculations
2100 batt on easy throttle would run you half an hr.
1320 weighs 86 gram.
You'd be lucky to get one decent flight out of a 250 batt.
decent one weighs 114 grams.
What does a full tank of fuel weigh?
Plus what does the oil weigh that's spread over the wing and fuse?
I think you said a lot of nonsense yet.
2100 battery offers to AXI 2808/24 (Max efficiency current 15A - > 75%) 8 - 10 minutes of flight with 11x5.5 prop depending on 3D maneuvers.
600 mAh receiver battery is good for standard servos (3.2 kg cm), 250 mAh is very good for micro servos (1.1 kg cm).
2 ounces full tank weighs about 60g.
How many bhp does AXI motor offer?
Freestyle2000
P.S. However I'm building an electric plane.
HAPPY NEW YEAR
