Crayon!
Don't forget to draw a crayon line down the middle of both sides of the hinge!
The wax will indicate the center line of the hinge during assembly and will repel the CA to keep the hinge flexible. The hinged surface will be much more flexible with this method, and there is no danger of hinge cracking.
If you're clever, you can pick a color of crayon that helps to hide the hinge.
