RCU Forums - View Single Post - Kit building essentials
Old 12-31-2006 | 07:05 PM
Pa-18cub150's Avatar
Pa-18cub150
Default Kit building essentials
Ok I have deseeded on a SIG Kadet Sr. as a first kit. What will I have to have to start the project?
I already know the top three
· Money
· Time
· Space
I have been in the hobby for a little over a year. So all three of the above are starting to get stretched to the limit with projects, repairs and completed ARF’s.
I keep reading about build boards. I assume this a board that I lay the plans on and pin and glue the kit together over.
I am also assuming that a sheet of ½ OSB just wont cut it, but is the Magic Magnet building board system necessary as this may be my only build?
Has any one made their own simple build board? I have read posts about glass and steel boards as well. Do I need something like this?
I have CA, epoxy, finishing rosin, balsa putty, exacto knifes, CA applicators, covering iron, and T pins.
What more should I have to make this a pleasant and rewording experience.
