RCU Forums - View Single Post - Jack Stafford Chipmunk
Old 12-31-2006 | 08:59 PM
WacoNut's Avatar
WacoNut
Default RE: Jack Stafford Chipmunk
I put the glue down on the skin in a squiggly pattern then rolled it out. I put very little glue on the sheeting, you could hardly tell the glue was there. Once I had the glue rolled out on both skins I used a spray bottle to mist both sides of the core. I applied the skin to the bottom of the panel starting at the L/E then rolled to the T/E then flipped the panel over and did the same to the top skin. As soon as I had both skins on I moved it straight to the shucks and put the weight on top to hold everything tight until it dried.
Next is to add the balsa T/E and L/E and wing tip. I will add these to the panel tomorrow.
Anthony
