RE: What do you have your conversion in???
ok so im a plane junky, i have recently embarked on conversion engines, i have had a 120 size cap 232 hanging in my room for some time now, wife let me buy it on our honeymoon believe it or not, it had a 120 surpass yuck no vertical just flat line flying, havent been able to get the mula to get a big glow so i recently saw on this site converting weed wackers and chainsaws, im hooked, i have spent the past weeks untill 2 am working on my 3.3 homelite, swapped soldering job on an antenna for it. its been a ton of fun working on it think it comes out to 50 couple ccs the only trouble ive had was cutting all the excess junk off of it fins, all the stuff mounted to the crancase cover and replaced the rubber hose mouted carb that goes over the reed valves, have motor mounts for it all welded up im hopefully gonna fire it up tommorrow, look out fellas ill never buy another zdz for as little as i have converted my new engine for, any ideas on what prop to run on it? have fun and anyone put a conversion on a showtime 100?[>:]
