thanks for pointing that out i forgot......when you put the throttle servo in just adjust the ball on your carb to be facing down (you should be able to find a little set screw to adjust that)and then you should be good atleast for me it was but if you have any problems just let me no and ill be happy to help you as best as i can
and yes either 1 of those raido trays you posted wil work
