RE: Should I use pusher prop or reverse rotation of engine?
Well when you use a electric starter you are trying to loosen your prop nut or spinner. Your probably better off to use reverse rotation so you don't have to order in special props and if ground clearance is an issue a 3 blade can be used. I know my LHS doesn't stock pusher props.
