RE: Suggestion for Entry Level Heli?
hello Dbuck,
Try this old trick; remove and install the tail rotor blade several times or more. This should result in a slightly looser fit and will allow the blade to "slip" a little rather then break when it hits anything. Good luck on the CX2.
