ORIGINAL: Commander_Bob
I looked back at the manual for the BCPP and YES I did mix up the leads. I feel so retarded. Now it works fine but I have not flown yet because it's too early. I will have to tell you how it goes.
Thanks a lot guys I thought for a second it would not work and I wasted my good money.
Justin
Just try to guess how I knew....
And yes, rob, I got it working about 1230 last night and I just hold the stick to the left or trim left and it stops. Totally flyable but unsatisfatory performance, I think because of the time lag in the bl esc for the tail. But I ditched the square-ended 3020 prop and went back to the other one and it works better. Still experimenting.
Up to 428 grams with the supre skids on, looks great , I also put a GWS tail boom piece on that is about 3 cm longer than the stock boom.
Be sure to set the auto-low-voltage cutoff to a "lower" voltage on the tail esc than on the main--guess what happens if you don't---
riiight....
