RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 01-01-2007 | 01:06 PM
  #586
Tall Paul
Default RE: E-FLITE BLADE CP PRO
ORIGINAL: Jellyson
Be sure to set the auto-low-voltage cutoff to a "lower" voltage on the tail esc than on the main--guess what happens if you don't---
riiight....
It'll be more exciting, but not as "plummety" as it would be with the main motor ESC reaching LVC in flight.
It is nice to see those LVC points do work! I noted that when I switched back to Nimhs from Lipos in one plane. The motor cut off way too quickly!
