RE: Should I use pusher prop or reverse rotation of engine?
If you can reverse the engine rotation, that would certainly be the way to go simply because you have a lot more props to choose from if you can use normal tractor props. Not only are pusher props not always in stock but the selection of diameter and pitch is limited.
