RE: Should I use pusher prop or reverse rotation of engine?
Many thanks for your comments & experiences. Paul, the engines I that I have that can be used via reverse rotation (by rotation of the front housing by 90 degrees) are the Irvine 40 & Royal 45, both being dual ball bearing. A reverse crank is not necessary under those circumstances. These engines, incidently, use the same muffler.
