RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 01-01-2007 | 11:31 PM
  #595
noguy's Avatar
noguy
Default RE: E-FLITE BLADE CP PRO
Ok I need some expert help please.
I installed the DD and did a few test flights...Everything flys wonderful except for the power seems gone.
I used to lift off with plastic sym-blades just over 1/2 throt. now is around 3/4...also full throttle gives a pretty weak climb compared to before....
I tried balsa blades and it was much better however still much less power than before the DD...
I also notice the 3in1 now has a red light in hover indicating 3in1 is *****g out. The light used to be green in hover and only went red in a hard climb...
Please let me know your experiance with this mod and if you saw similar power loss due to the bigger tail motor.
I am flying 800mAh eflite batts. I believe I read the robmoney or someone was flying with DD and a brushless with these batts?
Also my fly time on one of these batts seemed to go way down with the DD?
Help I dont want to fry anything if this is not normal for this mod.
Thanks, Noah
