ORIGINAL: weeber24
Hey Doc,
When those nylon bolts do shear off, do you have to drill them out of the blind nuts? I think I'll give it a try, what could it hurt since if it saves me from having to rebuild the undercarriage.
An easy way to remove broken off nylon bolts is to heat a screwdriver with a lighter and insert the hot tip of it into the end of the nylon, making a slot. Then twist the bolt out.
