low wing plane
I had that happen on an own design plane only worse. I would give right rudder and it would turn left. I put about 1in. more dihedral under each wing and it was fine. When you give right rudder, with dihedral, the left wing goes forward giving it more affective incidence, causing the plane to turn right. The opposite with anhedral.
