low wing plane
I was thinking about youre posts and was wondering.If i fly the plane inverted and move the rudder I should see some normal yaw in the plane due to the cg being below the wing anding more stability. thiswould prove the need for dihedral in the wing.If it does the same thing stall and drop the nose it needs more tail volume.
______________-
joel
